http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/clutches.html
This is all in the tech section.
I believe the slp setup I linked has some clutching setups.
			ALLFUN112
Thank-You so much!!!!! I will be busy reading the rest of the day !!!!
ALLFUN112
Thanks much to all that have sent info,,I have found some great info on heelclickers and how they work,,I am going to re-build both primary and secondary,,,i want this to engage around 5500 rpm and hold a constant pull on the motor all the way to top end speed,,found a great set-up,,sogetting all the parts together and this kart should hit way hard for the word go and carry the same hard move all the way through,,Thanks again,,i learned so much in 2 days,,hope this will work out
