extremeviper
How can I identify which carbs I have to put the rubber plugs in the proper place the sleds an 89 but I think the motor is newer because it has the oil pump from a 93 please help me identify the carbs/motor for my 13 year old kid as he has a hard time keeping up with me and my 16 year old on a srx and viper, any help appreciated...
Yamaha Nutz
there is no difference in the carbs ....the rubber plugs always cover the pilot jet and the center hole
extremeviper
Yamaha Nutz
I know for a fact that this info is not true ..........go ahead and leave the pilot passage uncovered the sled will run pig rich once off throttle
extremeviper
Yamaha Nutz
Thanks again seems there is also a mistake in the manual leading to some confusion View attachment 62195
seen that more than a few times ....after thinking about that further on your original post looks more like the original 87 EX 570 carb compared to the phazer
crazy canuck
Can you mix phazer 1 and phazer 2 carbs? Found out someone previous broke off one of the float bowl pin mounting legs so I am hoping to make a good set of carbs out of 2 damaged sets....
Also the 2 black plugs in my carbs do not fit very well in the holes and are loose, is there anything you can put on them to make sure they will stay put (fuel impervious silicone or jb weld?)?
PZ 1
- Mar 12, 2005
Start from the top and read - post 2.
The float bowl will hold the plugs in place. Do not use silicone or JB weld. If you want, get new plugs and they will likely fit tighter.
Throttle Junkie35
It depends. I tried that once. Somewhere along the lines they changed the top of the carbs. The difference is the height so you have to look at them closely. Also, NEVER use any kind of sealant on carburators. If the plugs are loose the sled wont run correctly. Buying new plugs is really your only option.
