ontarioyamaha
And I normally lead so I had no indication my lights were not working till after dark
Coltfz
- Jan 31, 2023
Sorta random but I couldn’t see the original post, I was having a no crank and no spark issue I removed these two relays and put them back in and it fired up not sure but just trying to see if this would cause a no crank and no spark issue ?If you remember you inspired me when you helped me with my crank issue.
http://www.totallyamaha.net/forums/showthread.php?t=99058
Sent from my SGH-I337M using Tapatalk
Click that link, then delete the “forums” out of the address, then it will work
totallyamaha.net
PTO Cylinder Not Firing
This is my first post so excuse me if I make mistakes. I have recently rebuilt a 2003 Viper 700 triple. The reason for the rebuild was a spun crank (PTO cylinder). Ever since the rebuild I can't get the PTO side cylinder to fire. It's running on 2 cylinders and about every 5 seconds the PTO...
