cummins6.7
Hey guys finally got time to pull the motor out.. turns out it's not crankshaft that seems fine (for now) just burned down another piston. Which was just rebuilt 300 miles prior and was thought to be caused by clogged pilot jet. I'm going to split the cases and clean and inspect everything and probably have the crank checked since it will be out. Any thoughts on what may be causing this to happen? Carbs were torn apart and cleaned 300 miles ago.
