2000 SRX600 triple Step by step carb clean?
Ok carbs cleaned replaced the float valve and replaced all the Orings sprayed and blew out all orifices . Put back in sled left box off for initial run started up on third crank ran ok for few minutes then giving it gas it would do wind up sound and backfire smells like it is running real lean or gassy also ran better with chock on one for few minutes then it started running crappy again then turn choke off and it ran ok forfew minutes then same simptoms . I set pilot to what it said in manual at 2 turns out what should I do next to get it to run better .
