auji700triple
Primary has a www spring, stock weights with 4.5g rivets loaded in both holes, secondary has a 51 45 helix with green spring wrapped at 70 and then tried 80 with same results 8100rpms. Powervalves are adjusted correctly and the gearing is not far from stock.
What I find funny is that my buddie is running the exact same setup in his 01 srx but able to reach 8500 on the dot. Matter of fact we swapped sleds on the lake and wow... 8500 compared to 8100 is 2 different sleds. What's next?
