steveg_nh
I suppose anything is possible. But a dirty pilot would cause a no idle situation not high idle right? I just cleaned the carbs about a month ago. I'll keep my eye on it.
You would think that a plugged pilot jet causes low idle because of the lac of fuel, but it does the exact opposite. It creates a lean condition therefore increasing the idle. Easiest way to check is while it's hanging, flip the fuel enrichener (choke). If the idle drops right away, this points towards a lean mixture. Of course there is more then one reason for lean idle, either not enough fuel or too much air. An example of this is worn crank seals or cracked carb boots. Keep us updated if you find anything.I suppose anything is possible. But a dirty pilot would cause a no idle situation not high idle right? I just cleaned the carbs about a month ago. I'll keep my eye on it.
I admit I don't have any experience with aftermarket exhausts, but I can tell you that a partially blocked pilot jet will cause idle hang. The mere fact that a blurp of the throttle or a flip of the fuel enricher brings the idle down tells you the mixture is lean while hanging, and adding a shot of fuel brings it down. I also have personal experience of idle hang that was cured by cleaning the pilot jets with a wire. We might have to agree to disagree, but as you stated it doesn't hurt to clean the pilot jets, it's relatively easy place to start and doesn't cost anything. It's also worth mentioning that carb cleaner and compressed air is not enough to clean these jets. You have to get a wire in there and scrape the inside of the jet. Sometimes it's easier to replace themI'm not saying dont check your carbs. Brethren a plugged pilot will not cause a idle hang. A lean condition yes but not a idle hang. In fact if plugged bad enough won't even idle off choke and will just bog out. A rising idle is from a air leak. A idle hang happens when pipe is hot and your comming down in rpms to stop. Usually after lo g run or riding midrange to long. The pipe will hang up and not want to idle down. A quick blip of choke or throttle brings it out of that rpm and it idle down. Best fix is set idle at 1200 ish and blip throttle comming to a stop. The Yamaha viper "idle hang" is not a lean condition. But do double check that carbs are clean and no leaks. That damn idle hang comes and goes for no particular reason. Just pay attention to your sled. I've checked plugs a 100 times with a chop at idle hang and never lean!
Just to update this on the idle hang situation. It did it a few times today so I pulled over on the trail and lowered idle to 1200-1300 as it was before today. Rode 80 miles and didn't hang once.totally forgot to keep it there when I raised it before.
