Seth437
Hey guys, I have a 98 srx 700 that I bought used last year. Stock jetting, v force reeds, stock air box, a hauck helix with only the letter G on it for markings (so not sure what the angles are on that helix? If anyone knows that may help) Mbrp can. Comp test was good plugs look good ( light brown ). I serviced, cleaned and set the power valves ( they were pretty close anyway) belt is good and sits just above the sheeths on the secondary. I am only getting 7700/7800 rpm most of the time sometimes it will climb up to 7900/8000 on rare occasions but then it only stays there for a couple seconds then drops back down until IÂ’m going like 80+ mph then it will creep back up to 7900/8000. I have bumped the spring pressure up to 9 and 3 on the helix with no change. It was on 6 and 3 and I moved it up in 10 degree increments with no change in rpm. Please help
Thanks in advance. Seth
