Hi, has anyone put a sc-3 skid in their viper 121 inch. I found a really clean 121 sc-3 and need some measurement specs for installation, does anyone have any info I could get for this swap, would like to put a yamaha mono in , but everyone I found are big bucks and don't have the shock included.
Search function should give you tons of info, that is a popular swap.
https://totallyamaha.net/showthread.php/43641-SC10-2-into-SRX
https://totallyamaha.net/showthread.php/97127-SC3-template?highlight=sc10
https://totallyamaha.net/showthread.php/97636-SC10-III-skid-installed?highlight=sc10
http://www.jbshocks.com/tech.html polaris stuff but still good info in the how to do a swap
staggs65
I did 4 or 5 sc10 3 swaps into yamahas back in the day. As said above try searching using some different wordings. There's tons of info on doing those on this site.
Bconrad625
Yes it is
Bconrad625
Yes it is now
staggs65
Hahaha, what is it now
okay, I have done some searching on ty and found some info on mounting the sc-3 skid in a srx but not much on the viper chasis, is the srx chasis the same as viper except for having shorter travel, can I use the srx measurements?, will I need a drop bracket? Thanks for any more help.
The measurements will be the same, I read and understand that the viper will need drop brackets.
