Need to find a good spot to get power for a 2001 SXR wiring harness.
I used to use the brown wire that was an un used 12V up by the headlight on my 1997, but
the new harness has the exact same plug, but the pin and brown wire are no longer used on the newer harness.
Where is the best place to get power on the 01-02 sleds?
A couple of bucks
The unused reverse plug in that is right around the stator. There will be a plug that isn't plugged into anything.
K, that would work, but would like to find something up by the headlight.
Wonder if I could tap into a gauge light?
I don't understand wiring much, AC, DC ect.
Just need to know what color wire I can use, lol...
A couple of bucks
Your EGTs will be under the windy? I mounted my to the handlebars. That why I suggested the unused reverse cannon plug.
yep, they are in the dash
A couple of bucks
Ahhhh you have those two 'blank-off' places on each side of the instruments right.
roudyroy1
reverse beeper plug
s10mike
I like that, and may use that idea, but isn’t there something in the headlight area to tie into?
s10mike
Im sure there is. I didn't want to cut anything. All my stuff will come right back off like it was never there.
A couple of bucks
Yes, those are what I used with my 600 twin installed.
Just need to know what wire to clamp it on.
Is the power up at the headlight DC? Same as the reverse power wire?
A couple of bucks
Yep..
In theory....shouldn't I be able to splice into a blue power wire that go to the gauges for backlighting ?
A couple of bucks
I wouldn't see why not. The absolutely only thing to keep in mind is if the amp draw from the EGTs are compatible w/ that wire size. Keep in mind .... I am the furthest thing from being a sparky!!!! Just using common sense.
I would add that if you have LEDs in your cluster, your probably just fine.
Great !
I knew you you could figure it out for me ! lol
