Ok I know I was planning of selling this sled but I figured a carb cleaning and new pull ripe and it would be running. I did both of them and went to fire up today and I'm not getting spark. I had my my tester on it and I was only getting inconsistent and weak spark. I had one good spark with the tester and it almost started. I thought perhaps it was the coil. I had a spare and swapped it out. Confirmed ground from wire continuity to motor.
I did replace plug caps a while back but can't find the resistance they should measure. Also not sure if there is a way to jump out the kill switch just to check.
I'm pulling my hair out.
Sent from my Pixel 3 XL using Tapatalk
