Working on a 99 Vmax 500 that I picked up and was wondering what recommendation people would have in regards to clutching. Machine is totally stock and just looking for maybe a little more aggressive trail setup. I really don't want to spend a ton of money on it if possible. What recommendations do you have?
A couple of bucks
Sounds like something for Maim.
00/VMAX 500 8ab-00 2.4 2.4 Stock 3 4100 7700 My tech reads 7600 with this combo, but the motor loves it. Still good backshift too. Run stock soft belt. stock 47/41 red
6-1
(70/80)
Much better shift out with helix change, lost top end at *60, gained it back and more at *80, and back shift is pretty darn good. Belt wear is excellent. Trail - Aggressive vmaxjohn vmaxjohn@chartermi.net
this is the set-up i used on my 01 sx500r. the only change i made was i used thundershift 40g base weights loaded the same as he did as they are bolts so it is easyer to add weight if i needed to. if you have the 8ab weights in your sled, just follow the rivit settings and helix. made the sled an awsome corner to corner one.
6-1
(70/80)
Forgive me but what should I look at changing? Springs, weights, Helix? And if so to what and what brand?
A couple of bucks
For sure:
1. 8AB Yamaha clutch weights
2. Six 2.4 gram Yamaha rivets
3. 8BVFA Yamaha helix (basically)
4. Three engagement shims. Or a slice of schedule 40 that's @ .125 thick.
Any Extra $:
Brand new W-P-W primary spring
Brand new Red secondary spring
Brand new belt. I've had great luck w/ Carlisle Ultimax belts. Yours is a MAX1118M3.
Any Extra $:
any chance you have parts numbers? also are you saying you only recommend Yamaha parts?
A couple of bucks
Yes I suggest these used Yamaha parts as they'd be cheaper than some new aftermarket thrown in a box and tested very little. Plus .... it is what I know. And to top it off, you can tell anyone that it is all stock. (Stock from what is a whole nuther story.)
The 8BVFA helix is the only identifier that I know on it. I cannot remember what sled they were on. An RX-1 mabey?????
RX1’s and Apex’s
Think part number is 8FA-17604-00-00
Bought one a week ago on eBay for $12 used, but hard to find.
They are stamped “8BVFA” on the helix
A couple of bucks
Here is a thread that lists the actual angle of aftermarket(mostly) helixs. Not just the advertised angles from each manufacturer.
https://totallyamaha.net/showthread.php/61494-List-of-aftermarket-helix-angles
Try to stay w/i 1* of the 48/42 helix that Maim stated.
As far as the 8ab clutch weights .... the 8ca weights are the same profile and work well too. They are just a bit heavier. The rivets would be .8 in both holes w/ these 8ca weights on a 500 twin.
the helix i listed is a dalton helix witch is still availible new.
I don't understand this, I am 10 kph faster running at 8000 with my VT 500, than on 7600. On all dyno tests I've seen, it seems that it makes the most hp between 7750 and 8050
http://www.m-performance.com/Grafik/Dynobilder/yamaha/yamaha500/xtc500-98/grafxtc500.jpg
http://www.m-performance.com/Grafik/Dynobilder/yamaha/yamaha500/vmax500-00/grafvmax500-00.jpg
http://www.m-performance.com/Grafik/Dynobilder/yamaha/yamaha500/venture500-99/grafventure500-99.jpg
OK I just want to make sure I have the correct part numbers and quantities
Primary spring (white - Pink - White) (1) 9051-58315-00
Secondary Spring (Red) (1) 90508-536A9
Helex (8BFVA) (1) 8FA-17604-00-00
Weights (8AB) (3) 8AB-17605-01 or
Weights (8CA) (3) 8CA-17605-01
Rivets (2.4 Grams) (6) 90266-06002-00 or
Rivets (.8 Grams) (6) 90261-0628-00
Shims ????
why will I need the shims and how many? What part number?
Thanks Rick
Shims ????
Thanks Rick
A couple of bucks
I believe you have it. But just to be clear .....
Either three 8ABs w/ the six 2.4g rivets.
OR
Three 8CAs w/ the six .8g rivets.
Everything else looks good. I do not believe you'll find the shims as they are discontinued.
OR
So I just found a used Helix that the seller shows a part number of 8FA-17604-00-00 on it. Looks like the helix is stamped 8BV31. Is this correct?
A couple of bucks
No. That is a 43*. The first letter after the V is the indicator. An 8BV71 is a 47*. An 8BV10 indicates a 41*. An 8BV51 is a 45*.
The last # is unimportant to us.
A couple of bucks
Here is a 47/41 w/ a .. Make Offer option. It is a Hauck I.
https://www.ebay.com/itm/Hauck-Heli...791893?hash=item420dd34815:g:LVcAAOSwbl9d6F4-
So I had a chance to take the sled out for a ride yesterday with all the new clutching upgrade and I have to say it ran great. Thanks for all the help. The one thing that was not so good was the belt. Carlisle Ultimax belts. MAX1118M3. I put 40 miles on this belt and every time I stopped the belt would squeal like crazy, I switched back over to my Yamaha belt and not squealing for the rest of the day.
Vincent
Well-known member
You need to adjust your secondary to compensate for the wider belt.... Been discussed on here hundreds of times
A couple of bucks
Take the belt off and scrub the sides. It still has precure on it from when it was cured. Also ... see below.
https://totallyamaha.net/showthread...-Drive-Belt-Slipping?highlight=Secondary+shim
A couple of bucks
Did you take those shims out and put the Ultimax back on. I bet a dime to a dollar that the Ultimax rode higher up in the secondary.
