When they state 1 - 2 mm in throttle play is that before the TORS bottoms out on handle or after? I adjusted throttle cable so I am at 1.5 mm but that is when it bottoms out in the TORS. After doing so my oil pump marks do not line up it. It is short of opening all the way. The reason I was adjusting is after a carb clean and replacing TORS switch the throttle cable had not been adjusted properly. Throttle body was not opening until throttle gap was almost 1/2" which in turn was opening my oil pump way ahead of time. Sled was loading up (Rich) the longer we road and I believe it was getting too much oil.
