Hello all….long time member just getting back to the forum ! I have a 2001 SX700R with reed spacers and 1 layer head gasket. I recently picked up a set of NOS PSI Modblaster triple pipes in the original box. Going to send them to Jet Hot for coating. I built one of these when I had a one new back in 01 but didn’t keep any notes….. Anyway, I am looking for Clutching and jetting for this set up…..running at 1800 ft. 10-30 degrees F….. Thanks in advance ! Howie
Any of that help?
Thanks for the info Tom....! Looked through all the info there and can,t seem to find any info for the PSI pipes specifically. I wonder which pipes are closest to the PSI configuration ? I may just go with a Power Inc. or Bender set-up…..I have some info on the PSI set-up but a lot of it refers to PSI kits which are no longer available. I would need to know what is equal to a “PSI Green spring “ as well as a “PSI progressive helix #8868”….. Looking to run at 9000-9100…. Thanks…!! Howie
I would think the Bender Set up would be very close. If I remember correctly those Pipes target RPMs were very close of not the same.
Awesome..!! Thanks Tom ! Great to know that…. Will be a good place to start..!
I had a 97 700sx and put the psi pipes on it—- I have my psi triples original paper work some where—- give me a call— I’ll look for it—Tod 2607019033
Dang I can’t find it….. it’s got to be here somewhere… Tod
If you find it, can you take a pic and upload it or send it to me to post?
Yes … of course—- I know I dug it out a couple of years ago for someone else—-If you find it, can you take a pic and upload it or send it to me to post?
i have the original stockblaster setup! if that would help ya out i can give you the specs.
Can you post it here? So we can use it as a ref in the future?
Benders run at 8600 rpm.
An 8cr with 13.3 inner and empty outer will get you close rpm wise
heres the psi specs!
Did it upload them successful? It looks like we cant view them.. Can you email me them? webmaster@totallyamaha.com
sent to you Mr. I could not up load them
