Track to tight 98 vmax 600 xtc.
Tjc702
Milford PA
I bought a Challenger track 679-9793 with a 1 inch lug. It said it was a 151x15 252 pitch. I have a 4 cogs on the driveshaft. I installed it and it doesn't seam to fit right on the cogs and it is way to tight. I didn't compare it to the old track. What is wrong?
Did you mean 121x15?
A new track can fit ugly when you first put it on due to the folds in it from being bundled up. It's going to need to be run a bit and adjusted after that...
if you can pull the track around the drivers by hand, it will work fine. had one where i beleived the parts guy on driver pitch and discovered i was wrong when i went to rotate the track. man that one sucked.
