Tjc702
I bought a Challenger track 679-9793 with a 1 inch lug. It said it was a 151x15 252 pitch. I have a 4 cogs on the driveshaft. I installed it and it doesn't seam to fit right on the cogs and it is way to tight. I didn't compare it to the old track. What is wrong?
EotS1
Did you mean 121x15?
A new track can fit ugly when you first put it on due to the folds in it from being bundled up. It's going to need to be run a bit and adjusted after that...
if you can pull the track around the drivers by hand, it will work fine. had one where i beleived the parts guy on driver pitch and discovered i was wrong when i went to rotate the track. man that one sucked.
Tjc702
I got it to fit. I had to grind the outside lugs on one side about 1/4 inch to get it to fit.
Sometimes the outer drivers move on the shaft either inward or outward.
You could have just pressed that driver in too.I got it to fit. I had to grind the outside lugs on one side about 1/4 inch to get it to fit.
