Comet 108 tuning
So here is the latest. We've had some decent snow, so I've done quite a bit of testing. The result has been this. No matter what I do, I cannot get over 80mph while riding in a field. With the exact same setup, on a hard pack road, I accelerate over 90 easily. I for the life of me cannot figure out why this would be. I've changed secondary springs, primary springs and weights. All the way from a Blue primary to a Silver/Black Primary and a Purple primary. Nothing changes the end result. I've even played with the Helix.
At this point I am left to wonder if there isn't something else wrong. I did notice a few times that when I was removing the secondary it would slip and then catch once and a while. I like to keep the key towards the top, so I would spin the secondary slightly moving the sled forward. This is when I would get a slight "slip". I can't imagine that's normal, and it makes me wonder if there isn't something else going on.
Okay, so I know I've said this before, but I actually think I've finally made progress. I started to question if the clutches were out of alignment so I dug around for the alignment tool. Once I found it, I measured the alignment and it looked like they were just barely off (hard to tell because the tool is a little thin at the end to measure). So I added the thinnest of a spacer as I could behind the secondary. The result? Well I went from racing up to 80 and hitting a wall to now getting up to 90 and beyond. Seems hard to believe that tiny little change made that much of a difference, but well, it did.
Now that I have that solved, I'm waiting for my tempa flow to arrive to install. I'm running very fat right now, so I'm excited to see how the sled will run once it's properly tuned.
I still will play with the clutching a little to see if I can squeeze more out of it, but for now, I'm satisfied that it's finally running mostly correct.
Installed the TempaFlow system. It was stupid simple to do. Noticed an immediate difference in the sled. Before, I was way over jetted. EGT's were around 800-900 mid range and 1100 WOT. Instantly shifted to 1100 in the mid range and 1250-1300 WOT. Definitely making more power. The issue I'm having now is that I seem to be out of tune with my clutching now. The primary was getting really hot. So I went to a heavier spring/weight combo thinking I needed more grab on the belt. Made the change and the primary was still really hot. Perhaps I need to loosen my secondary spring, but I thought I did when I switched from the yellow secondary spring to the blue secondary spring that was recommended on here before. Not sure what to do for sure at this point.
The sled is running pretty good right now. The primary is still getting quite a bit hotter than the secondary. I have been adjusting the primary to a stiffer spring and loosening the secondary, but I'm thinking now that I'm going the wrong way. Would stiffening the secondary spring make it not open as fast and prevent the primary from slipping?
A softer primary spring will make it upshift harder. More belt squeeze and pull the engine down harder on acceleration.
Sounds like you're living the struggle of myself and Peak Seeker. But this year my sled even off the pipe still hits 90, so not worse than stock. I firmly believe I have secondary issues and want to try a roller secondary, but I'm not sure what my helix options will be there. Probably nil. Of course I have stock Yamaha clutches, but I did find the wrong primary weights were absolutely impossible to work with. And the sled changes dramatically with the weather which you've no doubt seen yourself. I had a pretty good cold weather calibration cooked up and now I'm getting a warm, sloppy clutch setup going. The need for that change arrived overnight, it was crazy. I believe these triple piped readheads are more sensitive to jetting as well. I.E. if you're over a size or 2 you take a bigger hit than if you were on a stock single exhaust. Mine has SLP pipes FWIW.
Correct, but I could counter that with a stiffer secondary spring to slow down that up shift, no? Otherwise, I'm not sure how to stop the primary from slipping.
Sounds like you need the TempaFlow. I installed it on mine and it's been phenomenal! My EGT numbers have been consistent ever since I installed it. I've run it at temps close to 0 and all the way up to around 36 degrees. Should be good down to at least -20.
Some of my technical buddies...clutch for cold day with a sticky soft compond Carlyle XS drive belt. Then on a warm day install a slippery hard compound yamaha drive belt. Generally a 150-200 rpm change when heat soaked. Just a thought.
So here comes a new snow season. I decided to try to use AI to solve some of my problems and I came up with some interesting answers. What I found out is that I still may be using the wrong belt. What I learned is that the belt I'm using wasn't even available at the time this setup was put together. So I asked AI to tell me what belt size I needed based on the clutch geometry. It gave me a belt measurement that was .2" shorter than what I'm running. I believe this is a huge reason why I couldn't get past 80 mph in the snow but could run just a little over 100 on hard pack.
Something else I learned that was very interesting. Stock Yamaha clutches have an overdrive ratio of .90/1. The setup I have with the Comet 108 EXP and the Bearcat secondary has an overdrive ratio of .80/1, so higher top end speeds are achievable. It also gives me more low end pull with the oversized secondary. So in theory, my setup is superior in every facet. More low end pull and more top end speed. Here's to hoping I finally get the puzzle solved.
My new belt arrived today and I think it is indeed the right one. Ultimately, it's the Arctic Cat 627-011 belt. The 011 is no longer available, so I went with a Dayco replacement HPX 5011. Fits like a glove. Thank you AI lol
