I know this has been discussed before on this forum, but I need to ask you guys again. I have a 2002 Viper, which I had to replace the engine. I installed a engine from a 2004 Viper which has a knock sensor in the head. My 02 Viper did not have one. Since this was done I have only ridden it for a couple of miles to make sure it ran OK but then the engine light came on. I have read your posts talking about the knock sensor but I am not sure this relates to my problem. At this point I need a little better idea on how to fix it. Yes I do know I can just install the head from the 02 Viper & forget about the knock sensor, but I think it would be better if I could use the knock sensor & hook it up right so the engine light would stay off.
I will try to install a picture I took with the knock sensor installed in the head with the wires wired tied next to the head. When I bought the 04 engine that is how I received it.
Rich (TrueBlue)
Rich (TrueBlue)
