GasCans
Sorry but no...I have not. I am however sure, it would be a great read if you have a link?The book says them in #3 which is stock.
Have you ever seen my info about worn needle jets in other threads?
littlejohn
- Dec 10, 2023
Interesting I will check that outIt's in the 2002 Technical update book from Yamaha.
See post #35
1999 vmax 500 - seems like its missing at lower rpm and getting 4 mpg
This sled has 4400 miles on it and it's super clean. I am at a loss as to why it runs so crappy. Any thoughts? It will still pull 8100 rpms and makes all the right noises at higher rpm - just not good at all down low. Plugs are black. Starts up and idles fine. Kinda sounds funny at idle...
However, depending on miles, there will be wear which means moving the needle clip around won't really matter much.
with the milage you have stated, you just need to move the washers from the botttom to the top to pull the needle out farther to eliminate the mid range lean issue. brother did it to his 02 viper after it blew up and did it to my dad's 05 sx venture 700 when he got it. dads has 11000 km on it with no issues.
on re reading, with the mbrp can, you will need to get it ceramic coated or use header wrap on it to keep the can hot. brother ran one for a few years on his 02 and kept getting inconsistant rpm on long lake pulls. what he found was that it would tac full rpm with the can hot from running in the trails. once it started screaming across the lake, the can would cool off and it would not pull the rpm until the can warmed up again. wrapped it with header wrap and it would as consistant as stock can on same runs. running stock can, no issues on same type of riding. jetting was good with mbrp as with stock can.
littlejohn
- Dec 10, 2023
Let's have a pic of the needles ....if you feel they are "worn" replace them . Set your needles on the #2 setting with the two shims below the clip cowboy and adjust your pilot screw 1 1/2 to 1 3/4 turns out and report back.
littlejohn
- Dec 10, 2023
Also make damn sure your float height is correctwith the milage you have stated, you just need to move the washers from the botttom to the top to pull the needle out farther to eliminate the mid range lean issue. brother did it to his 02 viper after it blew up and did it to my dad's 05 sx venture 700 when he got it. dads has 11000 km on it with no issues.
littlejohn
- Dec 10, 2023
I picked up an assortment of main jets, gaskets and fuel line hose yesterday. Planning to open up the tops and pull the slides this morning and finish up my benchwork before putting them back in with 153.8 jetting and adding some new new fuel lines.
Where should the needles be set at?
littlejohn
- Dec 10, 2023
littlejohn
- Dec 10, 2023
It's not the needle that wears.Let's have a pic of the needles ....if you feel they are "worn" replace them . Set your needles on the #2 setting with the two shims below the clip cowboy and adjust your pilot screw 1 1/2 to 1 3/4 turns out and report back.
littlejohn
- Dec 10, 2023
littlejohn
- Dec 10, 2023
littlejohn
- Dec 10, 2023
I apologize I had to go back and re-read what you had written . Needle jet wear !who said they were ?
littlejohn
- Dec 10, 2023
Nitro I'm sorry but I have dealer level manuals and I'm just not finding these specs . What page of manual ?
GasCans
Keeping this thread on topic.....
Just got done cleaning the first of three carbs. Needles look good and clip is on the middle (third position) with 2 plastic washers below it. I'm installing new 153.8 main jets as shown below. Are these good to go back in on position 3 with washers under it as shown?
You have it correct.Keeping this thread on topic.....
Page 2-9 of the book I mentioned. It says Power Launch'02 on the cover also.Nitro I'm sorry but I have dealer level manuals and I'm just not finding these specs . What page of manual ?
Don't matter anyway, the information has been provided.
littlejohn
- Dec 10, 2023
Your picsKeeping this thread on topic.....
GasCans
This was a lot of fun guys. Thank you for all the additional info. My buddy Darryl sent me the maintenance specification page (65) with all the jetting variations based on elevations and temps which was handy. I took the carbs off the rack, cleaned the entire body, slides and all parts thoroughly. Have 2 left to complete tomorrow and then I'm onto greasing the sled and changing out the chain case oil. Taught my 2 boys as we went along tonight. They enjoyed it also. :-)
