rubber carb plug/alternative
rickk
ontario
working on a 1993 Yamaha Phazer 2 that i recently purchased and cleaning the carbs and could use some replacement rubber caps (MPN: 8V0-14118-00-00) They seem expensive to replace just wondering has anyone thought of a alternative thing to use as a cap? To my understanding it just has to plug/seal the hole just wondering if anyone has had success using something other than the factory part?
Mine only needed to be replaced about once every 20 years. Last a lot longer than a $75 belt. Pretty cheap maintenance.
my problem with buying the part is its getting hard to find anyplace with stock available and will be a couple weeks before being delivered
There were some folks making Billet pieces that used replaceable o rings.
This is why I went with TM38s. You can still buy genuine rebuild kits from Mikuni.
I ended up borrowing a track hole cutter for installing studs 1/4" and rubber from a old truck mudflap so far its working not sure how long but it works for now
