sloTJ
Hey TY! I need help/tuning suggestions for my vintage snox sled. I built a 1985 XLV 540 fan specifically to run leaf spring vintage classes in WI. Nutterville BeaterCross, Arpin, Ditch Banger, etc type events.
Current setup: bone stock engine, oil inj deleted, boyesen reeds, 40mm Mikuni round slide carb jetted 420m/45p, AA5 tube, 7dh2 needle, 2.5 slide, wahl bros throttle block, rsi bar setup, psi SRV pipe, stock gearing and clutching… tallest lug height you can run is 1.25.
What gearing and clutching would be best to run in events like these? Ditch the stock primary for a comet or P-85? Weights? Springs?
Improvements I know I need are higher engagement and snappier response clutching wise, somehow plastic skis on the leafs, hydro brake setup, newer ripsaw 1.25” SR-V seat… Anyone else with more experience on setup would be super appreciated! Thanks.
BornYamaha
All I got is that I would say go with the lowest gearing you can fit in there. I believe those things come geared to do around 80MPH. You will never need anything close to that kind of top end. If you do lower the gearing you will almost for sure need more primary weight. Not sure what clutch that year has on it. If it has the YP clutch the 570 Exciter 87M & 82M weight work better than the 8VO weights I suspect would be in a YP of that age. They are also heavier. Make sure the shift RPM is right. I know more about the old Phazers than SRV/XLVs. Good Luck
there used to be a company that made a leaf spring kit with plastic bottoms but have not seen it in years. ski skins allowed?
Back in the day...I had great luck installing a Polaris p85 primary and Polaris secondary on the older Yamahas. You would have to get a machine shop to modify the jack shaft to accept the keyed 1 inch Polaris secondary.
I have them on my 1972 Moto Ski Grand Prix....nice addition for sure.
Plastic Ski Conversion Kit for John Deere, Kawasaki, & other 26
This kit includes everything you need to install a pair of modern plastic skis on your John Deere or other brand* snowmobile with 26" leaf springs**. This kit is a direct bolt-on for 1980+ Liquiire, Trailire, or Sportire. The benefits of using a plastic ski include better handling, less...
newbreedparts.com
sloTJ
Thanks for the comments,
I ran the sled one weekend and it definitely needs clutching changes and a taller lug track and hydro brake! I did OK on it. I believe it was “lean popping” when cold if getting out of throttle then right back in it. Ran 32:1 premix Klotz. May need to go up on the pilot for next season.
If you can find a good used set of 8R6 SRV 540 cylinders. They have bigger reed valves than the XLV 540 cylinders. You will need the SRV 540 intake manifold as well. Install a set of 2001 SRX 700 reeds or better yet...go to a SRX V force reed. Ditch the air box. LOL. Way to tight for that motor.
Take .020" off heads if you are allowed. Aftermarket head gaskets are much thicker than genuine Yamaha gaskets. You can buy the VK 540 steel layered head gaskets from Yamaha and take them apart and tailer the squish clearance with less layers.
If your XLV 540 has the Phazer style clutch? Try and find the old Silver/silver primary spring. Part number 90501-55487-00 and 8vo ramps.
Try and find an 8k4 helix out of an old ss 440. they are a dual angle 45/39 helix. The 540 loves that helix.
The secondary clutch is a crappy clutch to try and get performance out of. I have had decent luck with the polaris atv red secondary spring in them. With the 45/39 helix. I think it was set on #4 and 180 deg preload.
Gearing 17-29 is good all round unless you are looking for big top end MPH. 18-29 then.
Just for a reference my ss-440 with 40mm round slide is running 430 Mj. 45 pilot jets. 2.5 mm cut away.
Good luck.
Good luck.
as to the hydralic brake, we did make a plate to use a yamaha xt350 front caliper and pads onto an old skidoo that was set up for vintage ice racing. i think the brake master cyl came off of a formula 583 sled with the brake line. stopped that bugger quick.
