jessev1978
- Feb 23, 2026
Hello I recently removed the reeds on my 95 VK540 and found one reed box/cage had the rubber vulcanized material separating from the aluminum block. I have been searching online and the used ones I find are looking like they will start falling apart also.
I can get a new cage with reeds from a 2017 Yamaha VK540 for a decent price compared to stock new for my sled.
The 1995 and 2017 Yamaha VK540s use the same head and the same cylinder head ( I believe the engine is the same 540xx two stroke) . The carbs are different for the two years.
It looks like the reed cage will bolt right on seeing it's the same head. The reeds on the newer 2017 VK look transparent and maybe that because they are a lighter (weight wise) reed.
I am wondering if anyone here knows if I can swap them into my 1995 Yamaha VK540? Maybe it would be a *performance* upgrade?
Thanks for any help in advance.
i know from past research that you can use xlv/srv reeds in a vk as it is the same motor. did research looking for a used engine for a buddies vk540 III as his toasted the crank when it blew up.
have not played with the vk540 v enough yet to know how interchangeable they are with the old ones.
RON HYDRAULIC YAM
jessev1978 this is the picture of your year and looked up 2017 and only found the
3 cyl , 4stroke...
I have reeds from a 93 , which show same part number . Not sure what the motor
came from , other than older and used bigger reed cage. I would need to locate
the correct bin and check them . Mine had the crank seals blown out on
the PTO side (expect starting aid) before I bought it. Marvelous engine as it ran
fine , except only idled on 1 cyl.
Anyway , don't suppose you are in Ont , Canada .
I will try to have a look at them and see what this vulcanized rubber is about .
Ron
3 cyl , 4stroke...
Ron
RON HYDRAULIC YAM
Found my reeds . They appear to have had a dip in liquid rubber but such a
fine precise layer , they look like they where spray painted .
Took some pictures with dimensions , No reply on where you live.
I recently got a spring by post and took over two weeks despite
BOP barn of parts shipping them the day after ordered. They may have
a good set as well.
No sign of peeling
Ron
a good set as well.
No sign of peeling
Ron
