1985 Yamaha SRV 540 problem
Apex2006
McHenry, IL
I picked up an 85 SRV that runs extremely high idle and bogs and backfires when pressing the throttle. The throttle cable is fully adjusted as loose as it will go. It looks like the previous owner bypassed the wires connected to the TORS by looping them together. I did notice a broken wire on the bypassed loop going back into the TORS switch connector on the throttle body. I didn't think this could cause such a high idle scenario. Can that cause this phenomenon?
sounding like a bad crank seal or carb boot. spray both areas down with quick start or flammable brake cleaner while it is running. if it picks up more rpm, that is the problem.
