RHodgins
- Apr 11, 2026
The knuckle at the bottom of the strut that holds the ski won't come off. I removed the two pinch bolts and it loose on the strut but come off. It looks as if the strut has a sideways notch at the bottom that coresponds to the bushing in the bottom knuckle and that the only way to "unlock" the knuckle is to remove the bushing. Am I right? If not why won't the bottom knuckle come off?
RHodgins
- Apr 11, 2026
If you have the ski off, there is a hidden set screw hiding on there that helps secure the foot to the strut. I believe its a 2.5mm allen and chances are it will be so stuck you wont get it out due to the fact they are so easily stripped. Find it, try the removal, and then drill it out or physically just beat the base off as a last resort.
RHodgins
- Apr 11, 2026
Got the bottom knuckle off but never saw the set screw you mention.
RHodgins
- Apr 11, 2026
low slung
Depends on the wear in the joints.I put the plastic one between the two metal shims(SPI kits have the metal shimsI'm buying this kit to replace whatever I can get out/off. I'm good with the collars and bushings but where do the plastic washers go. Never saw them on the disassembly.
Loading…
fortnine.ca
NorthofSixty
You need to loosen the allen head set screw for the foot to slide off of the strut. I usually have to use a fair amount of heat to break the set screw free. Be careful using impact tools with small hex (allen) tips as they are often brittle and can easily shear off in the head of the screw and the you are really stuck.
