M marcush New member Joined Dec 24, 2003 Messages 100 Dec 31, 2003 #1 If you install a polaris clutch on a yamaha do you use in the same neighbourhood of weight as you are using in your yamaha clutch
I intoodeep New member Joined May 2, 2003 Messages 69 Location Sylvan Lake, Alberta, Canada Dec 31, 2003 #2 If you haven't bought the Poo primary yet i would contact Hartman Inc they sell em and set em up for your sled. But yes, I would think you should start with matching the weights and spring combo as close as you can.
M marcush New member Joined Dec 24, 2003 Messages 100 Dec 31, 2003 #3 I picked up a brand new one off ebay for real cheap. Thanks for your input. Tom at hartman told me the secondary needs a 22mm offset. Any other input is appreciated.
