Polaris P-85 clutch install on a yamaha
marcush
If you install a polaris clutch on a yamaha do you use in the same neighbourhood of weight as you are using in your yamaha clutch
If you haven't bought the Poo primary yet i would contact Hartman Inc they sell em and set em up for your sled.
But yes, I would think you should start with matching the weights and spring combo as close as you can.
I picked up a brand new one off ebay for real cheap. Thanks for your input. Tom at hartman told me the secondary needs a 22mm offset. Any other input is appreciated.
