red devil
I was wondering if any one can check this with their viper? Hold the brake on and hit the throttle and tell me how much the motor jumps on the clutch side.Also what is the best torque limiter to buy. Why I checked this is because i keep putting weight in my clutch and it still pulls the same rpm and seems like its getting worse. Last year I was alittle lower rpm than needed and the only thing I changed was primary spring (same color) with shims in it and it jumped up atleast 400 rpm's from where it was. Is that normal? THANX GUYS.
