Well I finally got around to posting pics of my racepak udx dash I installed on my 01 SRX. It was a pain in the butt, but the end result was worth it. My speedo is now run off a jackshaft sensor (last pic). Me egts are off in the pics because I just started it up for the photo and it was still cold. It's nice to have everything built into one dash such as 3 egt's, speedo, rpm, actual water temp, fuel level, high beam, oil level warning, odo, and trip. It also recalls the top speed and rpm, and has a warning light for any problems such as high egt temp, high water temp, and high rpm (all custom set for the sled its installed in). I also blocked off the holes from the stock gauges with clear lexan from behind.
