WANT TO KNOW THE MPG ALL YOU GUYS ARE GETTING WITH THE SX MODELS PLEASE LIST IF YOUR SLED IS MODIFIED OR STOCK, WEATHER YOU CHANGED JETTS.
MY SX:
1998 SX
BORED SILENCER
PIONEER PERF. LONG TRAVEL KIT
OEM CLUTCHING
OEM JETTING
ALTITUDE ABOUT 500-1000 FEET ABOVE SEA LEVEL
8.8 CAMO TRACK 120 STUDS
MPG 10
WOULD A JETT CHANGE INCREASE MY MPG [/b]
MY SX:
1998 SX
BORED SILENCER
OEM CLUTCHING
OEM JETTING
MPG 10
MichYamaha
- Nov 10, 2003
- Rochester Hills, MI
- www.michiganclassics.com
My 97 600SX (twin) is getting 10-11 MPG - stock engine with 2K on the clock.
Oultman
'99 SX 700, stock engine, I am getting 14-15 mpg, although the style of riding can change this quite abit, but consistently 14-15, trail riding. It's a nice change after riding cats for years and their 6-7 mpg I was getting with my zr 580
you need to finish your sled with reed notch, and head gasket mod and finally the clutch kit , thats were the mileage comes from....my sx never worse then 12 but have seen 17 on it. Thats was a 97 sx700.
Mr. sled
didnt the 97 sx have a overdrive clutch on it, do you think that has any bearing on milage for the 97
Be happy
I get 7 to 8 out of mine with a tempa flow. Might have something to do with ridding style. maxdlx
no overdrive clutch, that was never sent out in production....riding style , I would get 12 no matter how it was pounded....
BlueIronRanger
- Nov 26, 2003
Worst of 10mpg best of 14mpg with my 01' Sx600R tripple. ALL stock Jetting and it does run somewhat rich.
sxviper320
Ihave a 00 sxr600 slp pipes 142.5 jets 45 pilot jets stock gears 50-44 helix .I average 12-14 mpg .Doesnt change much if ran hard .
I modified mine on a step by step using the tech. page. By far the biggest increase in mileage came from Turk's clutch set up. I still don't have the clutching nailed down but I am hoping for more gains. Increased mileage by at least 30% with significant performance gains. I am sorry I can't give numbers but I don't usually track that sort of thing. It's just an observation at the pump. A double bonus of Turk's clutching is a very cool set of sheaves. I pounded that machine for 3 hours straight, up and down the rpm's, breaking trail and being nasty. Barely even warmed the clutches. Used both an 8dn and Dayco Ultimax 2 belt with very little difference in rpm's and temps.
1 layer removed from head gasket
2 1/8 hole in can
jetted 1 down on mains, needles down 1/2
21/39 gears
Carb heaters on
track at 1" drop for 16 pounds
Driver- 200lbs
Air Temps--9 Celsius
deep and light snow
2 1/8 hole in can
21/39 gears
Carb heaters on
Driver- 200lbs
deep and light snow
8 ab weight 4.5g both holes, y-s-y primary, 51/43 helix green secondary 50 degree, 8dn belt, stock gearing 23/40, one layer head mod, tempaflow, reed notch...12.5 mpg last time checked
robmc
- Jul 1, 2003
I've got a stock 02sx600r getting just about 12 m.p.g. riding aggressively.
Joe SixPack
I have Heelclicker clutch with Tempaflow and Reed spacers. 10.5mpg pushing powder and 14.5 most all the time otherwise as high as 16.5.
Mr. Sled you said you thought the head gasket mod helped-I have not heard this before. Has anyone else noticed this?
Hey Maxdlx, you should be getting way better than that no matter how you are riding it. Unless of course you are always riding in deep powder, and/or hill-climbing.
BLUEBALLER
2000 SXR700
stock mains, stock needles, pilot jets up one size (47.5's), fuel screws out 1.5 turns.
clutch kit, mbrp silencer.
8300kms
elevation 500-1000 feet
worst 7.8 MPG
average 10 MPG
friend has stock 02 viper and we're within $1 at the pumps.
both ride aggressive
8300kms
worst 7.8 MPG
average 10 MPG
dhess
98 700 sx with stock motor and clutching. Mains down 1 size and needles down 1/2 clip. Consistently 14 - 16 mpg with 5300 miles on her. How do you like the long travel kit? I've got a set of Viper shocks I'm thinking of revalving then add the wide radius rods.
SpartaSXr
fuel mileage
97 700 SX, jetted down, layer removed, bored can. I ran with a stock 00 700 SXr and a 440 Pol XC all day and would constantly piss them off at the pump. They would always use 3 - 5 gallons more than me every day for the complete trip. I was around 15 mpg. The pol 440 was a thirsty little bugger but he was running 9 grand all day trying to reach out and run with the triples. We had a 800 ZRT that was getting 6 and he was not happy. That thing drank oil and gas like it was free. Heavy turd too.
wildman
I get between 14 and 17 mpg with my '99 sx700, usually averaging around 15mpg. My setup includes:
slp triple pipes, triple silencers
head cut
reed spacers
carbon tech reeds
long travel suspension (front and back)
C.R.Y. Performance clutch kit
geared higher
viper seat (no change in fuel mileage
head cut
reed spacers
carbon tech reeds
geared higher
