ski
Can anyone tell me where I can find Factory horsepower ratings for 1997 Yamaha snowmobiles? In particular I am looking for 1997 Vmax 500XT, but I would like to compare it to other models as well. Thanks alot.
I would guess that motor stock puts out about 80+ hp.
On this topic wondering what and 01 vmax 500 if any difference and how much the 600 twins put out since she's getting a new 600 top end this summer
ski
I can't believe no one has specs on this topic.... Searched all over the web. I was sure somewhere on here I could find it.
yamaholic22
the '01 500 isn't any more power, they are around 82 horse. The 600 twin is around 93 horse. Definately not the strongest 5 and 600's out there, but rock solid
sxray
topend
if you are using a 97 600 topend make sure you use the updated pistons
500 motor is around 86-88 hp. The 600 twin or triple sx motors are around 96-98 hp on average. The 500 twin if you're looking to get some more HP out of it buy a set of 600 twin carbs, wire harness, and cdi. Adding those parts will give you the advanced timing like the 600 had and put you up around 92-94 hp. The 600 twin can also be massaged to up around 105-107 hp with the right parts.
ski
carb specs on the 500 are identical to the 600 except for fuel screw adjustment. Can the timing not be changed without changing the cdi? How about an aftermarket set of reeds? What whould they do to power band and response? Is the same gain available by doing the mod to the factory reeds?
yamaholic22
the 600 carbs have a bigger bore
ski
if they are both tm36 carbs I would have thought they would be the same bore as well. So yamaha modified the carbs for the 600 from the factory?
My 94 600 had TM38s but you're right about later 600s they dropped carb size to 36. Maybe look for a 94-95 Vmax 600 for carbs.
The 600 carbs have the throttle position sensor in them where as the 500 does not. Otherwise everything is the same. In order to adapt if to the 500 you need to swap out the carbs, wiring harness, and cdi. This will give you advanced timing for 8 seconds when you have the throttle wide open. Reeds won't gain any hp, but might make it slightly snappier.
Here you have some dynos on yamahas, no -97 500 but still its better than nothing.
http://www.m-performance.com/Sidor/dyno_yamaha.htm
ski
thanks .. .there is an xtc 500 there ... is that engine simialr to the xt500?
This would be the same as your 500.
ski
yes I found that one thanks....
yamaholic22
They had a sheet on there from a '96 500 and it made almost 82, which is right around what i thought. It was even a little leaner on the main (147.5 as opposed to 150)
Slight hp differences from the 96 pogo-stick model to the 98 (first year the 500 was in the pro-action chassis) due to some slight improvements in the motor and ignition timing. The SX, Vmax XT, and Vmax XTC, were all around 88 hp in 98-99.
yamaholic22
gotcha allen
ski
1997 was the first year for the pro action chassis with the 500xt... 97 and 98 are identical as far as I can see.
