srxguy
Does anyone make a turbo for 2 strokes?....
kawirider00
the problem with turbos on two strokes is the cases cant handle alot of boost with out blowing seals
Turbo
There use to be a place in Batavia,NY called Aerocharger.....I dont know if they are still around or not though. I know Bender racing is currently working on a turboed 2005 Mach Z so you might want to give them a call. They might be able to possibly custom make you something???? It would probably be some big $$$$ though.
sxviper32
what sled are you trying to turbo? here's a pic of a srx turboed.
yamaholic22
yea i was going to say aerocharger used to make them but i haven't heard anything from them in a couple of years.
kawirider00
aerocharger makes benders turbos for the four strokes
sxviper32
the srx pictured above is from powderlites. if you do turbo a srx, let me know what all you did. i might put one on my srx this summer. thanks!!!
03viperguy
I can say that a friend owns a dyno company and has done a LOT of custom projects, and he says that it isnt worth it. says only place it is any good is in the mountains where it would make up for the altitude. he tried like hell to get it to work (has a turbo vette and pushed it to 700whp and 700wlbft in his garage) and just couldnt. just didnt always work right
SpiderViper
well it would b cool if you could get some kind of turb other than nitrous because i heard that it kills your engin.
03viperguy
^^^^^ heh???
Brad
- May 23, 2003
Well bender has a turbo kit for the new mach z, so for they are up to 278hp for over 150 dyno runs with no problems, there goal is to achieve 300hp.
Junior
and they've dropped development of the apex turbo's 'cause the mach is making bigger gains with less work...Brad said:Well bender has a turbo kit for the new mach z, so for they are up to 278hp for over 150 dyno runs with no problems, there goal is to achieve 300hp.
DoktorC
Jr..I don't think that's the case...considering they are still developing their turbo grass sleds...a surprising number of them at that! I was talking to Gerry this weekend and he mentioned that the 4s kits are still much more popular..and has far more potential then the Mach.
03viperguy
besides, the 4strokes can still handle boost a LOT better than the 2s.........
Junior
03viperguy said:besides, the 4strokes can still handle boost a LOT better than the 2s.........
this is your professional opinion?
03viperguy
this is what I have found after knowing and talking to a guy that has built a few turbos, a few engines and a few drag sleds. he owns a dyno company and I really take his opinions in high regard. land&sea dynomite dynomometers
Junior
ready:
aim:
fire:
http://www.atlanticdda.com/engines/index.cfm
my mistake, I guess your buddy knows better than detroit diesel, and by proxy general motors, and mercedes, and in the near future dodge.
03viperguy said:this is what I have found after knowing and talking to a guy that has built a few turbos, a few engines and a few drag sleds. he owns a dyno company and I really take his opinions in high regard. land&sea dynomite dynomometers![]()
aim:
fire:
cacsrx1
When I put boost to a sled its gonna have a 1 piece crank and pressurized oiling system. Comparing a 2 stroke sled and a Detroit is like comparing apples and oranges.
03viperguy
yes, exactly! and where are the 2 strokes, I didnt see them there. the bottom end of a 4 stroke yami is by far stronger than the bottom of a doo.
Junior
have you ever seen an SRX or a viper spit out a crank? I don't spend much time in the doo's so I can't say, but I've seen R1's do it, that site has 4 or 5 2-stroke turbo's guys, ya it's not a direct comparison, but I'm saying it can and has been done, it's not impossible.
