Dave_Vmax600
triple pipe, do something with the intake, and clutch it. then lighten the load.....should be a rocket
yamaracer18
yea def already got a maximum perf clutch kit, lookin for pipes let me know if anyone has some, and not sure what to do wit intake mayeb the king cobra intake in that kit
yamaholic22
dropping a tooth on the bottom gear will take away bottom end, and probably won't add anything on top end because the stock engine won't pull it and it wont fully shift out
redsnake3
i had a ripsaw on my 03' 121" viper which was stock at the time other than a heel clicker clutch kit. i was beating clutched f7's in the 660' drags we race here. at the time the track was pretty hard so I had it setup(susp.) so that i would take even the mountain sleds off the start.03viperguy said:and remember that the more power you add, the more traction you will need. unless you have a ripsaw already, the stock power is enough to overwhelm the track. any more power and you will simply spin the track FASTERtraction and less wight is the best way to start , imho
once i got my pipes and head and reeds i had to uppgrade the track again to a 1.5" track to compensate for the power. if you go piped and race him on the groomed trails get a bigger track. set up your suspension for alot of transfer and you should be surprised.
bolin22
dump the max clutch kit and get some heel clickers dude....
Boondocker or boss noss nitrous system, leave it stock looking and stealth he'll never know what hit him
That is looking like my plan this winter to keep some 800 rev's at bay
yamaracer18
heel clicker that much better? and nitrious will fry the motor wont it
yamaholic22
Heel clickers are a nice aggressive weight that will help get the power to the ground if you set them up right. You can put weight exactly where you want it and it will effect different parts of the shift curve. As for nitrous, it is possible to have a very reliable system if it is set up right, nos pro is the man for nitrous info around here.
yamaracer18
what does the heelclicker kit cost any one got a used one? or where can i buy
auji700triple
Not Very Expensive, i have one on mine... Last year i was running against some f7s in the 660(viper mtn).. i was like w/e its only a race no big deal right.. I smoked it outa the hole man... i was about 5 skiodo Lenghs to him in the middle and it just picked up.. about 60ft from the finish he cought me, i just watched him creep up on me and pass me barley when the line came.. so i decided to turn my sled in the Race Direction, and hopefully i can do somthign with it next year.
auji700triple
Oh, i was Bone stock then too
SlowSRX
- Mar 11, 2004
Pipes, head mod, propper jetting and clutching. Traction is your biggest issue with em. But they are beatable, don't believe everything you read on hardcore sledder. Most of its bullshit. F7's are beatable.
yamaracer18
yea i know traction right now sucks got 144 studs and still spinnin alot, does anyone have pipes they want to sell me?????? i need some
SlowSRX
- Mar 11, 2004
I'd go up to 168 on your studds, Look for pipes on e-bay if you don't want to buy new ones. Aaens are probrably the lowest on peak hp, but thats still what I'd buy. What are you running for a track? Where do you plan on doing most of your racing? The stock yokahama track is hopeless, 9830 with 1.175's or a ripsaw with 1325's is the way to go. the 1 inch for ice and glazed dirt roads, ripsaw for everything else.
yamaracer18
i wwas thinkin of hauck pipes, do alot of racing in groomed fields and shit some times on the lake, just the stock track wit 144 studs
yamaholic22
New style Haucks (aaen's) or the old style (CPR's)? CPRs make more top end power.
yamaracer18
i dunno guess cprs then cause i want mor mid and top
