ovalracer
cant get sled to run right! i have a 97 700 sx and it ran fine before i pulled the airbox off of the sled to fix a crack, i had to pull the coils off. I then put everything back together and now the ignition timing is way off, it runs really ruff and backfires real bad ,and will not gain rpm.
It is getting fuel and spark to all 3 cylinders, the only thing i can think of is maybe i got the coil order got mixed up when i put them back on? It just seems light it is firing all at the wrong times. I put the coils back on so the first coil goes to cylinder 1, then 2 and 3.The coil that has the orange wire to it is on #3. Please help!! mayme someone can post a pic so i can make sure i have them right? thanks
