Cam
Can't pull off the secondary, are there any tricks, suggestions, and if not where is the best place to hit it with the big hammer. Did a search and could not find any solutions. It's on a 85 Bravo, and could have been on 20 years?? Nut came off easy. Thanks Cam
yamyrider
have you used heat on it. Heat it up and knock her off.
Cam
looks like there is a dimple there on the shaft for a puller maybe a puller is required???? just a guess
bluewho
can you take the hole shaft off or turn the sled on its side and put wd 40 in the hole and let it sit.you would heat up the back of the clutch were we can not seeit but i dont think it would work.good luck
Cam
Plan on taking the side off for access to weld frame so would be able to use a puller, still hoping for WD-40 to work. It is on it's side now with the WD-40. So one would apply heat near the bearing on the frame? And if all these don't work what is the options?
Thanks Cam
Thanks Camdaytripper
- Nov 4, 2003
It looks tha same as my Ovation. This is what I did and it worked like a charm. I took my PH50 Snap-On air hammer with the tapered ended chisel and just gave it a quick shot right in the center of the shaft. The clutch popped right off. A tip here is to leave the nut on so it is flush with the end of the shaft. Using this method can be dicey but I've been doing it for thirty years with much success.
Cam
Pop and off, took side off and had a puller that fit. Put some pressure on, thought something might break, was puting tools away, going to check this thread then call it a night, low and behold. Heard a pop and it was off. Thanks for the help and suggestions. CamAttachments
Cam
Just when I thought I had it done. How does this "seat, secondary spring" come off? Should it just slide off? It seems stuck also, I have applied the wd-40, now any suggestions before force is applied. Do I go with the gear puller again? Thanks for any help. Cam
bluewho
still in a pickel is see can you take the gear off the other side and undue the bearing take the hole shaft off and put it standing up in a table vise. than beat the shaft down with a brass plate so the end will not get ruined.or a bigger puller with some more wd.
Cam
Well it's done, turned out the seat is on with a left hand thread, a couple of wac's with the hammer, brass, off it came. I hope that this information may help others, and thanks for the advice given. Rest assured I will have more questions as I try to rebuild this Bravo short to the best it can be.
