I'm thinking of putting hooks on my srx along with a 1 inch riser. Which do you guys prefer, 90 degree , 45 or non at all?
MTNMAN700
- May 27, 2003
I prefer 45 degree...
My only problem right now is finding hooks that will fit into a 7/8 aluminum bar. The wall thickness is greater, and I can't seem to find any that will fit...
rancidjo
I have a 90 on my brake side and a 45 on my throttle side. I like this combo. But I do use my 90 on the brake side ALOT more. IMHO, I would suggest short 90 degree hooks.
MTNMAN700 said:I prefer 45 degree...
I have a set that had to be machined down to fit my bars. Few minutes on a lathe and problem solved. Most any machine shop should be able to fix you right up.
Nate
TopGunnSrx
I have the 45 then 90 * hooks on my sled. I got em from Port and i had to shave mine down a lot so they would fit into my Pro Tapers
BLUERHINO
- Nov 8, 2005
I was thinking about get some to thanks for the info
PowerValve-700
vipertripplexxx
Firecrap Grips......you musta been in a pinch eh?
vipertripplexxx
PV7, If you look at you avitar, it looks just like a snake's head looking at you!headlights being the eyes, thats cool! With the blue lenses the lights look just like a set of eyes.
PowerValve-700
lol, yeah I think I lost some top end and reliability b/c of those grips. Actually they are identical to sportech grips. Yeah, I noticed the front view of the Vipers kinda looks like a snake so I added a set of fangs to finish it off!
auji700triple
looks pretty cool neil, Why the F-cat Grips??? wouln't that Make you're sled perform like crap??lol
I have the 45 and like them, haven't had any 90 so I can't compare.
Thanks for the info guys. PV7, your set up looks great (even w/the ac grips). I think I'll go with the 45s. So what everyone's saying is, I'll have trouble fitting them? They won't just slide in?
FuninAK
AlaskaJeff
Nice
Do you cover your sled when transporting? The reason I ask is with the handguards on is your cover a tighter fit? I have an 01 MM600 with 6" of rise and PowerMadd's loke yours. I've got a nice custom OEM MM cover that dosen't fit very well anymore!! Have you had similar problems?PowerValve-700 said:I have the 45* hooks, I filed them down to the outside diameter of the handle bars and slid on Firecat grips. I also cut 3/4" off each end of the bars so they weren't so wide. Installed a 2" riser and handguards, I'm really liking this setup.
PowerValve-700
FuninAK said:Do you cover your sled when transporting? The reason I ask is with the handguards on is your cover a tighter fit? I have an 01 MM600 with 6" of rise and PowerMadd's loke yours. I've got a nice custom OEM MM cover that dosen't fit very well anymore!! Have you had similar problems?
Well I don't trailer my sled but I had a Viper custom cover and it doesn't fit with the hand guards. Its fits with just the hooks and 2" riser though but it's VERY tight. Keep in mind I cut about 3/4" off each end of the bars.
MTNMAN700
- May 27, 2003
wanasrx said:Thanks for the info guys. PV7, your set up looks great (even w/the ac grips). I think I'll go with the 45s. So what everyone's saying is, I'll have trouble fitting them? They won't just slide in?
They'll fit in just fine with stock handle bars.
The aftermarket aluminum bars are thicker with the same OD - therefore you need to machine the hooks down a little to get them to fit.
