edunn69 said:The older SX has the same arms. Look for the 'V' ID mark on the front.
yamaholic22 said:all others will FIT on the srx, but they have different caster angles which changes the handling characterisitics of the sled, such as steering response and feedback. Vipers have a higher spindle height than the others, which would raise the front end, but you need the longer spindles to go with them.
edunn69 said:There are 4 different trailing arm versions.
SX/SRX are the same. ID mark = V
MM/PZML are the same. ID mark = S
All 9" 42.1" wide are the same. ID mark = R
All Vipers are the same. ID mark = M
The difference is in caster, shock bracket angle, spindle. Look at the identification letter on the front of the arm to identify.
1 inch is about it, but only with the GYT's NOT the newer low saddle or saddless typeso if i buy viper trailing arms, viper spindles, and use the stock oem srx skis i can lift it an inch or 2?
