skidooboy
i have never even heard of anyone running pilots that big. 90's???? REALLY???? i know that is not what bender suggests.
dcs does not come on because of rpms, it comes on due to a lean spot in the carbueration.
i think you've read into the timing spike issue too much and want to make that your problem.
and here you answered your own question: quote: but before i installed the throttle cable last night the sled worked fine, no signs of Bog after letting off the gas.
thats the first place i would start looking period. it wasnt the jets, timing, dcs before the cable, but it is now after the cable. sounds like the cable is too tight, and the throttle over ride switch is activating prematurly.
listen to don, and disable the tors and go for a ride. eliminate that issue. if it runs awesome, re hook up the tors, and go for a ride, if the problem comes back, viola your cable is misadjusted. put some slack in the cable till the issue goes away. ski
