Too much book knowledge?
O.K. let me get this straight.. You guys are opening the P.V.'s and then setting them too a tight clearance on the cylinder?
When you use the tester or let it idle down, this opens the power valves, which is tightening up the cable. This is the method of measuring clearance on the valve housing, which is the way the manual says to do it, and the only way I have ever done it.
This new method of feeling the cylinder wall would require the valves to be fully closed, i assume,... So now using the tester, or idling down would not be required.? I would mark the cable winder with a scribe when idling, so if the servo motor moves when you shut down the machine you can turn it back to the mark. Then adjust the valves with the "feel method"
S.S.viper and Snowdog, don't take my word for it, but you sound right in Questioning this method. Heck even the Bender PDF file says to do it the wrong way. I think bender was smoking something!!! Adjust to fully open then put zero clearance on the cylinder wall?? WHAT THE F***
Here's the linkhttp://www.benderracing.com/Default.cfm?SubPage=CustomerSupport_SupportDocuments
