2000sxr600
ok, I installed a new camo 1.25 predator track on my sled on Friday....rode about 100 miles on Saturday, no problems except the smile on my face LOL, rode about another 100 miles on Sunday without any problem but the last 15 miles my clutch started to act up on me.
ok first of all the sound the clutch was making sounded like my engine was like knocking....it would only make the noise when I would let off the gas and as soon as I would accelerate it would go away, it would also go away when I would lock the brakes up...
Any suggestion on my problem?
also waht is the point in changing spring colors? i have a black spring on my sx600r, should i chnge it?
Waterfoul
Check the rollers and fly weights in the primary. When these wear out they can make a "clunk" sound when trying to shift. Been there, done that.
**sj**
Life Member
sounds like the secondary ramp on is coming off the buttonslike a binding..take the secondary apart clean and retwist spring..also check your belt wear /deflection
vmaxjohn
Yes, definately check out your secondary.
Something else to consider, it might be, just maybe, the track loosening up and ratcheting. You should have about 1" of free droop when the rear is off the ground, no more. Good luck!
mikematthys
mine did that last year the spring in the primerary broke as for the colour of the spring is painted on with tuch up paint on the spring
2000sxr600
i hear alot of ppl running the green spring....what are the advantages of running the green spring over my stock black one?
**sj**
Life Member
more twist help backshift and sideforce to keep the belt from slipping especially when using a steeper angle helixes
2000sxr600
ttt, im still not understanding the point of changing springs?
greg
Check out these 2 links to the tech. pages. It explains it pretty well.
http://www.totallyamaha.com/snowmobiles/aaTECH/tuning/tuning.htm
http://www.totallyamaha.com/snowmobiles/aaTECH/Is Clutching Magic.htm
**sj**
Life Member
oh...one more thing...excessive play in the chainase could cause the clunk....is your chain in good gondition and tightened properly?
2000sxr600
i had the chain case all apart last friday...eavrything was good
