Oil pump adjustment problem. Video link attached
sandmanmike1
Wyandotte MI
I have having a problem with excessive oil comsumption and smoking. While running I can see oil spitting out of exhaust. I have a video attached. I went to adjust the oil pump free play which is supposed to be 1.10 inches but the most I have is a 1/4 inch. Is oil pump cable supposed to move the minute you hit the gas?
http://media.putfile.com/94-vmax-600-too-much-oil
on my 97 500 they were right on the oil pump. ones on the arm that swings when u pull teh throtel adn teh otehr is on the pump. u line up the one on the arm to the one on the pump at idol and then hold WOT and make shur it lines up again at WOT. after 3/4 throttle the oil pump if full open any way i think not quite sure. i watched ur vid and it snoked about teh same as my 500. just check the lines to make sure they line up at idol
You need to adj your cable to this specification for a '94 v-max 600cc;
27-29mm(1.06-1.14 in)
I would use the leaner side(29mm or 1.14 in) if i were you.
