fortress
Can you tell me if the sxr trailing arm is the same of the srx??? (2001) i did buy a used sx trailing arm thinking it would fit!! ;( i did buy just the left one
Bigmax said:Not sure why the new post... but you could check to see if the SX and SRX are interchangable but the SX-R (long travel) is definatley different. To use SX-R arms you would need to at the very least change both sides and would probably need to do the radius rods, tie rods, sway bar, etc. as well.
fortress said:ok, thx, now its clear,,, someone want a left sxr trailing arm?!?
