95 Vmax 500 pistons & rings or just rings?
fishx65
Pistons & rings or just rings?
Sled has about 4500 miles on it and runs great. 120 psi per cylinder. As far as I know the pistons and rings have never been changed. Do most of you wait for them to go bad or do you change them at regular intervals? I know that the pistons are fairly inexpensive, but if they spec out ok, what would be wrong with just replacing the rings? Also I've read that these cylinders should not be honed, is this true? Just wanted to see what the experts say!!!! Thanks in advance for the replies!!!!! I also posted this same thread in the v-max forum, wanted as much input as I could get!Hope thats O.K.
95 v-max 500
thos sleds will go alot longer than that before a rebuild. but if you got the $
go ahead and do it would'nt hurt.
