What size pilot jets with mods
dugedug
I've done the silencer mod, the airbox mod, and the reed notch. Now i'm bogging off idle and backfiring. Which, from reading other posts is because I need to get bigger jets. So what size do I need to go to? She's a 2001 SX700R. Nothing else has been done to it. Thanks.
jets
Forgot to mention. I'm at ~2500' with occasional trips to 6k' and a once a year out to the bighorn. The sx also has variflow. Thanks.
changes
Rule #1 - Only change one thing at a time
I would say you have a carb or airbox issue. I have heard of very few positive when you modify a xs airbox. I'd try a stock box and ck all carb settings.
Good luck
change what
I wouldnt go chainging air jets etc. This machine can rock without all of that poke & hope stuff. The reeds and can mod wont effect the jetting. I would try a stock airbox, and be sure carbs are clean and set up for the elevation/temp.
fuel
I guess I can try throwing some duct tape across the holes on the top of the air box and see what that does.
If you are jetted correctly, then with the mods listed the airbox mod is likely the problem. Some sleds will lean bog when you snap the throttle open. Roll into it easy and it will work fine. If this is the case, you can tape the hole you drilled shut and see how it works. Like I said before its not that difficult to tune, but doesn't make a big diff in the performance at lower elevations. The higher you go, the better the airbox mod works.
tuned
It ran perfect before the mods. I taped the holes up and it still bogs. It does fine if I choke it a second before snapping the throttles, indicating a lean. Rolls into throttle fine. The only thing is is that it seems a bit smokier, but that could just be me. Tomarrow I'll check and make sure i'm not leaking around the reeds... and i'll check all my vacuum lines once again.
What are your pilot screws set at (1 1/2 is stock)? I had to turn mine out to 1 7/8 to cure simular problems with mine. I had made several of the small mods as you(except air box mod). Soc :)
You need 47.5 pilots. Been der dun dat...this will fix your problem!!!
