Any hc set ups for a 2001 mm, stock with reednotch and a hauck headgasket?
Where do I start? I want a trail set up that hopefully does the same thing that it did on the srx, lowers clutch temps over stock. I like how the hc's really grab the belt when engaging, and backshifts fast in the primary.
I will have a 43 deg helix, yamaha green, hauck green and hauck red to choose from. Gearing is 21/40. It's jetted 141,3 in pto and center and 142,5 in mag, (it should be the other that is bigger?)
I will be using the 40-10s. I have all the tuning hardware and a gram scale if facing/grinding is needed.
By the way, thanks alot for the srx set up, worked really well and keeps the dcs light off pretty much all of the time. I can go maybe for a km or so at wot before it activates when jetted rich..
