sandmanmike1
Can;t see nothing man!!!
Wear limit on a '94 Ramp shoe is 1.0mm(.04 in)
Your only allowed that much wear on a new shoe
sandmanmike1
Secondary is from a 95 XT
how many miles???????
THKSNOW
They look "ok" (worn a bit) to me-- but--Better safe than sorry, they are cheap and easy to replace, go get some new ones.
sandmanmike1
I am unsure of the mileage. It is a little dirty ang I will clean. How hard is it take apart and reassemble by yourself
sandmanmike1
at ronnies.com they are 11.48 each. Is there a cheaper place to get the new shoes?
THKSNOW
You can buy aftermarket for about a buck a piece. My dealer sells the genuine yamaha for about $10 ea. A lot cheaper then new metal clutch parts...
Easy to take it a part, just take your time and pay attention to what holes the spring lines up in.
braindead1684
Those will work for this year prob, but if you are not using that clutch yet and don't need it to get out riding soon i would replace them only a few bucks i got genuine for like 7 each or something like that, also check the bushings and ramps ect for wear.
sandmanmike1
Where can I get them for $1.00 a piece. My local dealer wants 11.48 each for OEM
find your local kimpex dealer. he should be able to get them for you.
fishx65
- Jan 7, 2006
Mike, I just did mine on the black 95 V-max up in Irons. You can pick them up at Rec& Leisure in Farmington or order them from Shadetree ( About $2.00 each). I could'nt believe how easy it was! There will not be any tension at all on the spring when you get the three nuts far enough out. Just make sure to put marks on everything before you take it apart. Mine were about as worn as yours. Two of those sliders were completely gone on one of the red V-max's, replaceing them made a huge difference. I just got back about an hour ago, the side streets and two tracks are pretty good up there but the trails sucked!
