greg said:My manuals don't say if the VM500 has the built-in diagnostics. Did you check the owner's manual. If you don't have one, you can download one from www.yamaha-motor.com. The owner's manuals are under the parts and service section.
No i doesn't say anything that i seen...in your manual what does the
trouble shooting page say for a non working temp light??
Daman, my sled is exactly the same sled as your wifes new sled. The motor was bored out to a 600 about a year ago. Then after that is when all the suspension , clutch, and other upgrades were made. The motor now is basically equal to an older twin 600. After like 99 or 00 the 600's were triples, mine is a 2001. The blocks of the 500 and 600 twins are equal, but with different bores, and obviously internal parts. So having the block bored was easy, but it's still a twin. I never had the lights blink even before all the work was done to it. I don't think it has the computer. I didn't own the sled when the motor work was done. It was a family members sled. I used to drive it occasionally before I owned it though. But I might have a problem too.. not sure now..
maxout01 said:Daman, my sled is exactly the same sled as your wifes new sled. The motor was bored out to a 600 about a year ago. Then after that is when all the suspension , clutch, and other upgrades were made. The motor now is basically equal to an older twin 600. After like 99 or 00 the 600's were triples, mine is a 2001. The blocks of the 500 and 600 twins are equal, but with different bores, and obviously internal parts. So having the block bored was easy, but it's still a twin. I never had the lights blink even before all the work was done to it. I don't think it has the computer. I didn't own the sled when the motor work was done. It was a family members sled. I used to drive it occasionally before I owned it though. But I might have a problem too.. not sure now..
Yea thats what i'm trying to figure out if a 500 should light up on start up...
Now I can't remember if it even lights up.. I don't think so.. I know for sure it doesn't blink.
maxout01 said:Now I can't remember if it even lights up.. I don't think so.. I know for sure it doesn't blink.
It will do one or the other.....light up for a few sec. or blink 3 times.
I need to find more people with '00 '01 500's
greg
greg
The first picture is a 2002 VX/VT700; the second picture is a 2000 SX500.
Thanks. That definitely helps me.. hope it help daman too! What did you get these out of??
greg said:The first picture is a 2002 VX/VT700; the second picture is a 2000 SX500.
Beautiful Greg thanks!!!!
Now(Hate to bother you)could you post a pic of the
procedure for checking that temp light circuit??? the lighting coil i think...
