That sled was a gas to ride, way faster than a standard EX, completely diff motor and exhaust, of course I couldn't leave mine alone, I took mine, dropped a 94 600 in it, PSI low rpm twins, Cat secondary, what a gas, ran 103 on radar, a friend of mine still has it, uses it as a back up, I think he rode it this year, I also put a 94 Vmax skid in it, it was faster.[/QUOTE]
They should of been the same suspension?
From my post below !
The Original Pro-Action was used in the SRV, Vmax540 and the Exciter II and last used in the 94-96 Vmax 5-600 sleds. The SRV/Vmax540 listed the travel as 5.9" and the 94-96 Vmax 5-600 sleds as 8.5" ? I purchased the front and rear arms plus the rear shock off a 1994 Vmax 500 and the only difference is the newer arms are tubular verse channel for my old Vmax. The rear of rear shock is the same center to center lenght and all shock mounts are in the same position ! Everything matches up the same although I did not get the limiter straps from the newer 500 so, what is the deal ? I'm bummed where is the extra 2.5 inches ?
