Oconto County
- Dec 27, 2005
I had the mis-fortain of have an outside (stator) bearing fall apart, causing damage to the piston skirt which in turn cracked both the upper and lower crankcase. I do not understand how or why this happened.
What I need is a two piece crank to start the re-build. Is there one out there?
If it is easier, email me at bux@myway.com
richierich
i have both cases.let me know if you want them.
Some '97 had problems with bearings on magneto end of crank.
Yamaha installed 2 small bearings, outer bearing had trouble getting oiled.
Solution, replace with large bearing found in '98 motor.
