03viperguy
good pics! if you can get some close ups it would be GREAT!
My firekitty bars
Fourth pic is a before shot, to kinda see how much the 5 inch riser raised them. I'm guessing they are 2 inches higher than stock and definately more comfy. Yes, in order to fit the stock throttle you have to cut the end off of the f-cat bars to slide it over, then reweld or fit a 45 degree hook. I haven't gotten that far yet, ITS LAWNMOWER RACING SEASON, so my sled projects are in a holding pattern. Sorry it took so long.
03viperguy
thanks a lot! so those bars arent cut or anything yet, they are just plain stock, right? looks great! thanks again!
Harry Balzonya
- Nov 12, 2004
- corner brook,nf canada
- www.poppaduff.piczo.com
man thats a really nice lookin sled
where did you get the sticker kit to can u get a viper kit
Harry Balzonya said:man thats a really nice lookin sled
Thanks, the stickers are Redmaters and yes I believe he can make em for a Viper.
Yes these bars are all stock, no cuts yet. This is also with the 5 inch Rox riser. I basically just threw them on to see what they'd look like, since I knew I was running out of time.
03viperguy said:good pics! if you can get some close ups it would be GREAT!
Here are some close-ups... Mind you this is with a 1" riser. I plan to go with a 2 or 3" for next year.
BTW, the aftermarket elements work much better than the orig. stock ones.
03viperguy
AJ that looks terrific! how did you wire them up?? thats EXACTLY what I want mine to look like in the end
heat all the way to the end of the hooks?
I don't think you can get heat out on the hooks. My aftermarket heating elements didn't like to bend around the curve too much, so I got them as close to the bend as possible.
03viperguy
huh, thought the cats had heat to the hooke
03viperguy said:AJ that looks terrific! how did you wire them up?? thats EXACTLY what I want mine to look like in the endheat all the way to the end of the hooks?
Thanks!
No, like ejcamaro stated the elements do not wrap around the hooks. However, they do cover more area than the stock grips. They basically cover the entire bar minus the hooks. I think if I were to go with the SLP alumn hooks, they would probably warm nicely given the amount of heat the elements throw off.
I had the hooks so basically it only cost me $30 for the mod.
$20 for elements
$10 for two 8" Firecat grips
I wired them directly to the the existing wires (very simple).
03viperguy
any more updates from anyone doing this project on their sleds? I never got their as I found a good used mono and went to that project and kinda forgot everything else lol!
I swapped my bars at the end of the summer. It's a pretty easy install, the most time-consuming thing was to get the old grip off the oem bar.
Unfortunately we got our first real snow yesterday, so i have not tried it out for real yet. Hopefully i can give you my opinion this weekend.
03viperguy
so did you cut the end off the cat bars and use an aftermarket hook? what did you use for all the stuff. like warmers etc. thanks for the update!
03viperguy said:so did you cut the end off the cat bars and use an aftermarket hook? what did you use for all the stuff. like warmers etc. thanks for the update!
Yep cut the end off and slide the throttle assembly on (you don't wanna forget that
03viperguy
nice! how big of a rise do you have on it htat you needed longer cables? and what was your total end cost, if you dont mind sharing
If i'm not mistaken, the stock bar is about 3-4" taller than the Firecat. I had a 2" riser on before, and the pivot adapter is now raising it a bit. It's not that much higher i guess, but now when i can tilt the bar as far forward as i want to, it's going to be so much more enjoyable to ride standing up.
I wasn't really sure wether all the stock cables would work with my new setup, so i ended up buying some longer cables just to be safe. I've not changed my oilcable, i just rerouted it and it seems like it's going to work.
Don't mind at all. $200 + shipping for 6" riser w/pivot adapter ($82), bar, pad, warmers, grips, and hook. And an additional $87 for a stainless brakeline and longer gas & oilcables.
03viperguy
thanks
looks great!
