sxviper32
ya, modmmax i'm gonna have to fess up and say i'm "borrowing" (aka stealing, hehe) your wheel idea. can't beat the price and go with just about anything!!!
ModMMax
I have a pair of aluminum 8" wheels with 1" id bearings. $45 usd ea. If someone's interested I'll post pics.
BoRnWiThBlUeBlOoD
wow awsome looking sled... when is your seat gonna be there? mkae sure you post pics...cool sled!!!
ModMMax
Ordered seat from Boss (all black, high top wide, shovel pouch, nitrous sleeve) on their spring snow check plan. They will ship in Sept.
BoostMe
That sled looks awsome man, love the black look!! Any idea on final weight?? Also where is Sask are you located?? Thanx Scott
SRXM5
When I was finished with the sled after we built it all in full of fluids the sled weighed 595 lbs ready to ride as weighed on a digital 4 pad race car scale. When I owned it I had a mesh hood and a two wheel rear axle, which may have made the sled slightly lighter than what it is now but not much. I would guess its at just under 600 ready to ride as it sits now.
03viperguy
looks great! I have heard about bluprinting the skid, but what are the benefits? again, looks amazing man!!
ModMMax
Seats installed. Engine is finsihed. Pipes coated and installed. Tail rack finished. This priject is close to finished. Blueprinting the skid just means checking both sides to see they are identical. In my case, the rails needed to be straightened as did some cross shafts. Once aligned, I installed the skid into the tunnel without the track or springs and checked measurments on both sides throughout the flex cycle. Once I was convinced that it would move without friction, I removed it and installed the springs. I am just as fussy about the engine and shaft alignments. IMO, near perfect alignment helps to get all the hp to snow. This sled was built by SRXM5 and a buddy. Thanks for posting the weight.
ModMMax
ModMMax
Sorry. Pics a really dark. I'll reshoot and post later.
03viperguy
really looks pretty nice! who did the pipes?
ModMMax
They were coated by high tech coatings in Ontario. Second set he has done for me. I think his web site is www.hightechcoatings.com.
taylzee
Very nice...just need snow!
Hi man! Man that is a sweet looking SRX!. Really looks like a mountain sled!.
However I do have one question for you, have you made any modifications to the air filter / exhaust, (cold air kit / exhaust deflector) when thinking of powder bogging?.
My SRX has a 136" track with 2" lugs, bought it because I figured it had to be a gread mountain sled, however I`m having major powder bogging problems.
I just wondered if you are aware of this or if you have made any modifications to cure this problem that seems to occure to every SRX out there.. .
Again, nice sled man!
ModMMax
I only rode it on one trip last year and had no problems. You are right though, SRX's can have air intake issues. I installed SLP guage hole screens and installed 4 smaller ones on the deck above the air intake. Should help. There is a pic on this thread of the screens. Also, too tall a gear ratio causes the clutching to heat and go soft. I am using 19/42. Seems to prevent a lot of the heat soak. If your sled runs better first thing in the morning it may be a sign that you have under hood heat issues. Hope this helps you.
Mountain SXr
Costs
Nice sled.
So, what was your overall cost? I would love to do the same thing some day.
Nice sled.
ModMMax
Cost? Good question. I don't keep track because I know its more than I would want to spend. If you own the sled its easy to do the math on the items you want to change. A tunnel change is about $1000. Add the track ($800) and a used suspension ($600), clutch changes ($500), lightweight parts ($1200) porting ($600) cermaic coating ($400) a hood ($600) a seat ($500). It's easy to get 15k in a mod sled. Hard to get it back. If you are planning a project, make a list of possible changes and start researching the prices. In the end, the new sled of your choice will cost about the same. This route really only makes sense if you like building things. Good luck.
I agree with Modmmax, you end up with roughly the same money into it as a new one, but (hopefully) you end up with a sled with the features, handling, performance, etc. that YOU want, not the off the floor model built for the masses. And like he said, you better like to tinker in the garage.
BTW Mod, nice sled!
BTW Mod, nice sled!
